if u need help with vdj go on my utube see if that help if not do a respons and i can see if i cna help you
youtube username/ DJBADBOY224
COMMET AND RATE PLZ
COMMET AND RATE PLZ
Posted Thu 17 Jul 08 @ 5:39 am
badboy please dont double post you have a reply to this in the technical forum, please read this if you missed it :-
"badboy while your enthusiasm is commendable, i would advise anyone needing help to consult these forums you don't need to go anywhere else, firstly by an initial search in a particular forum suited to the question ie, technical, hardware, skins and plug ins etc and if you can't get an answer than please post your query to the relevant board, or you can also try here
your link to youtube is very misleading as it only shows a basic use of working the on off controls to the decks and pitch control, these boards are over seen by very very knowledgeable people and with many years of experience so if you wish to help a fellow user please keep any input you want to offer to these forums".
Posted Thu 17 Jul 08 @ 7:31 am
Badboy, please do not double post..all comment can be found in the thread you started in the PC Technical help forum..Thanks
Posted Thu 17 Jul 08 @ 8:46 am
