if u need help with vdj look on my utube acc see if that helps u if not do a video respons and i will try and help you
youtube user/DJBADBOY224
Posted Thu 17 Jul 08 @ 5:38 am
badboy while your enthusiasm is commendable, i would advise anyone needing help to consult these forums you don't need to go anywhere else, firstly by an initial search in a particular forum suited to the question ie, technical, hardware, skins and plug ins etc and if you can't get an answer than please post your query to the relevant board, or you can also try here
your link to youtube is very misleading as it only shows a basic use of working the on off controls to the decks and pitch control, these boards are over seen by very very knowledgeable people and with many years of experience so if you wish to help a fellow user please keep any input you want to offer to these forums.
Posted Thu 17 Jul 08 @ 7:13 am
