I'm currently using VDJ Pro 5.0.7 trial version with the dj console rmx. I've noticed while mixing between tracks that once I have the cross fader all the way to the side of the deck I'm mixing into that sometimes you can still hear the other track playing on the other deck. I can fix it by going back over just a tad (toward the deck that is being mixed out of) and then bumping the cross fader kind of firmly back over to the side I mixed into. But by that time it is really too late and if I was playing out it would have sounded like something messed up.
Has anyone else experienced anything similar to this with the console rmx or any other midi controller for that matter?
Posted Wed 16 Jul 08 @ 10:59 pm
Add your RMX serial number in your profile and if u decide to buy pro u can get a discount.
Posted Wed 16 Jul 08 @ 11:15 pm
I can't add it just yet b/c I have to RMA the console. One of my mic inputs is messed up.
Posted Thu 17 Jul 08 @ 1:22 am
There is, for some user's a slight bleed with audio in the cross fader whilst using the RMX in WDM, I get it too. Try the RMX in Asio mode it should clear it up.
I think the team are aware of it.
Posted Thu 17 Jul 08 @ 3:18 am
All the times it has happened to me I was using the ASIO drivers.
Posted Thu 17 Jul 08 @ 1:43 pm
