Forum: Old versions
Topic: headphone and deck problems
ok my comp crashed this weekend so i had to re upload my hercules on my vista computer but the problem is when i switch the decks on the headphones i lose volume in the output coming out of my speakers until i switch it to the deck that is playing...
any suggestions???
Posted Sun 13 Jul 08 @ 4:13 pm
its just a basic soundcard whatever comes in the vista comp....and its the mk2
You need to change the output settings on the sound set-up config in Virtual DJ only. it looks like you have your main output set to headphone monitor channels a quick play around in there should sort the problem out for you but I could be wrong . If it’s any help it’s happened to me and that’s what I did to sort the problem.
thanxs....do u think it could have anything to do with the drivers and vista maybe somethings not compatible with it or somethin???
