OK SO I HOOKED UP MY RMX TO MY MACKIE MIXER..RCA OUT PUT 1-2 TO RCA INTPUT 1-2 MACKIE MIXER. ANYWAYS WEN I HAVE IT CONNECTED A NASTY WEIRD NOICE COMES OUT FROM THE MONITOR... A STATIC NOICE WITH A CONSISTANT NOICE LIKE IF UR HOLDING UR PHONES BUTTONS.... BUT WEN I LOAD THE SONGS THE NOICE GOES AWAY. BUT THEN IT COMES BACK...I TRIED BOTH RCA'S AND 1/4 PLUGS....SAME NOICE. ?? WHAT CAN THIS B? OR IS THE RMX DEFFECTIVE????? SOME ONE?
Posted Wed 09 Jul 08 @ 1:57 am
Are you playing though "phono" or "In line" this does affects sound quaility, also you might have a grounding problem.
Posted Wed 09 Jul 08 @ 7:01 am
