[btw, i gotta head to bed now sorry, its super late in Norway now, so I hope someone else picks up... if not I'm back in some hours.. Best of luck, hope you get it working great :) ]
Posted Sun 06 Jul 08 @ 9:46 pm
Thank you so much for your patience and assistance! ;-) You've definitely helped me along.
I'll continue playing with the various modes and see if I can figure out what the heck's going on. I'll post up further if I run into more challenges.
Thanks!
Thanks!
Posted Sun 06 Jul 08 @ 11:25 pm
One last thing which comes into my mind. As the Demo Version you are currently using for testing is only a demo the Timecode CD functionality is limited. So you will lose timecode control after 10 - 15 min of playing. Then you have to restart VDJ to get timecode control again.
Someone may correct me if I´m wrong.
Best regards
Marcel
Best regards
Marcel
Posted Mon 07 Jul 08 @ 12:57 am
Gotta question on my video card side...I'm wondering if my video card is enough to handle VDJ without issues arising? If it's not...is there a way to run the video out of VDJ to an external video card off of my laptop?
Well, here's the tech specs of my notebook. I have upgraded the RAM to 2GB, which is all the notebook can handle.
Model
N6210
Software
Operating System
Genuine Windows® XP Professional
Bundled Software
Adobe Acrobat Reader®
Microsoft® Internet Explorer
Norton AntiVirus™ 2005¹
Fujitsu HotKey Utility
Intervideo WinDVD®4
LifeBook Application Panel
Microsoft® Explorer
Microsoft® Works
Quicken® New User Edition 2005
Software on CD
Depending upon your system's configuration, you may get:
Sonic RecordNow and/or Intervideo WinDVD Creator™
Key Specifications
Processor²
Intel® Pentium® M Processor 750 (1.86 GHz, 2 MB L2 cache, 533 MHz FSB)
Display
17" Crystal View wide XGA +TFT LCD
320 nits LCD brightness
400:1 contrast ratio
Memory
Two DIMM slots upgradeable to 2 GB total memory (1 GB x 2)
PC4200, DDR2 533, Dual channel³
Hard drive4
80 GB (4200 rpm) ultra-DMA 100
Dual hard drive configurations: 160 GB (80 GB-4200rpm x 2)
Video Controller
ATI™ Mobility™ Radeon® x600 with 128 MB of dedicated video memory
Supports PCI-E graphics, LRTC, and SmartShader technology
Multi-monitor management and multi-display support
Consumes less power with PowerPlay technology
Maximum internal display resolution: 1440 x 900 resolution, 16M colours
Maximum external monitor resolution: 1600 x 1200 resolution, 16M colours
Supports simultaneous graphics on built-in and external display
Supports dual displays mode
Audio
Realtek ALC 260
Headphone, optical digital (SPDIF), audio-out and microphone line-in jacks
2 internal stereo speakers and subwoofer
Media Drive DVD/CD-RW drive (8x DVD/10x CD-RW/24x CD-R/24x CD-ROM)
or Dual-Layer Multi-Format DVD Writer drive5 (8x DVD-R/+R, 4x DVD-RW/+RW, 3x DVD-RAM, 8x DVD-ROM, 24x CD-R, 10x CD-RW, 24x CD-ROM)
Floppy Disk Drive
Optional external USB floppy disk drive
Communications
Multinational5 56K6 V.90 modem
10/100/1000 Gigabit Base-TX Ethernet
Wireless Communications
Integrated Wi-Fi® and WPA Certified wireless Intel® PRO/Wireless 2915ABG Network Connection (Tri-mode 802.11a/b/g) wireless LAN with slider ON/OFF switch
Wi-Fi Protected Access™ and CCX Certified
User Interfaces
Integrated touchpad with intelligent scroll button
103-key full-size keyboard with a separate 10-key keypad, 19 mm key pitch and 3 mm key stroke
Ports
Four USB 2.0
4-pin IEEE 1394 port
S-Video Out
External monitor
Modem (RJ-11)
LAN (RJ-45)
PC Card Slots
One Type I/II slot
One ExpressCard™ slot
Media Slot
One shared slot for Memory Stick®, Memory Stick PRO™, Secure Digital card, and xD Picture Card
Battery/Life
Lithium ion (8-cell 14.8V, 4400 mAh, 61.5 watt hour)
up to 1 hour 45 minutes per battery7
Lithium ion (12-cell 14.4V, 6600 mAh 97.7 watt hour)
up to 2 hours 45 minutes per battery7
AC Adapter
Auto-sensing dual voltage support, 100-240V AC
Output DC 19V, 80W, 7.9A
Dimensions and Weight
404 mm x 295 mm x 43 mm/53 mm (15.9" x 11.6" x 1.7"/ 2.08")
Approximately 4.4 kg (9.68 lbs.)
Environmental
Operating temperature: 5°C to 35°C (41°F to 95°F) (ambient temperature); 20% to 85% relative humidity, non-condensing
Non-Operating Temperature: -10°C to 60°C (5°F to 140°F); 8% to 85% relative humidity; non-condensing
Service & Regulatory Information
Regulatory and Compliance
Energy Star compliant
Agency Approval
Emissions: EN55022 (CISPR22) Class B; FCC 15, Class B; FCC15C, 15.247; ETSI EN 300-328; ICES-003; Canada CSS210
Immunity: EN55024 (1998); ETSI EN 301-489-17 V.1.1.1 (2000-9)
Safety: UL and cUL Listed, UL60950 3rd ed. (2000), CAN/CSA-C22.1 No. 60950-00 3rd ed. (2000)
Telecom: FCC Part 68; IC CS-03
Model
N6210
Software
Operating System
Bundled Software
Intervideo WinDVD®4
Microsoft® Explorer
Microsoft® Works
Software on CD
Key Specifications
Processor²
Display
Memory
Hard drive4
Video Controller
Audio
Realtek ALC 260
Floppy Disk Drive
Communications
User Interfaces
Ports
Four USB 2.0
S-Video Out
External monitor
Modem (RJ-11)
LAN (RJ-45)
PC Card Slots
One Type I/II slot
Media Slot
Battery/Life
AC Adapter
Environmental
Agency Approval
Posted Mon 07 Jul 08 @ 3:03 pm
Afraid it MIGHT be too slow for video mixing on second monitor.
I got a x700 on a laptop, and it works, so maybe you are lucky :)
There are (almost) no such thing as external graphic card. Well there is, but its very new, and you need a PCI-E Express slot on your laptop to use it.
http://www.xbitlabs.com/news/video/display/20070111060818.html
Posted Mon 07 Jul 08 @ 4:01 pm
Thank you...well, I went in and took a dive on a new laptop computer in preparation for a second mobile DJ rig.
I picked up a Toshiba Satellite P305-S8822. Pretty nice laptop. I was after dedicated video card memory. With this one, I get 256mb of dedicated video memory.
Specs can be viewed here --->> http://reviews.cnet.com/laptops/toshiba-satellite-p305-s8822/4507-3121_7-32976928.html
I'll load up VDJ on this booger and give it a run for it's money!
Posted Mon 07 Jul 08 @ 7:56 pm
ah.. think thats an excellent choice for a PC, with rock solid specs and great brandname ;)
Posted Mon 07 Jul 08 @ 10:47 pm
Thanks...and it was a breeze to set up VDJ with it! VDJ is performing very well with this laptop. The video side also is nice and smooth.
You were a big help with me understanding the setup features of Timecodes. ;-)
Posted Tue 08 Jul 08 @ 8:13 am
np ;) Glad it works well :)
Posted Tue 08 Jul 08 @ 8:15 am
