Anyone lknow how to calibrate the jog wheels on a Dac 2? In 5.1 the inside wheels are too fine. I need them a little bit courser to scratch. I right clicked on the Dac 2 in the remote control tab oif the config menu, but it only has options to activate or deactivate the controller and choose the com pot.
Posted Sat 05 Jul 08 @ 9:17 pm
Anyone?? Cell, Norway, Tayla?
Posted Mon 07 Jul 08 @ 10:00 pm
You can just download another mapper. Some mappers have very fine movement (as i like it), others have very fast movement. Just test a few to see which one you like. :)
Posted Tue 08 Jul 08 @ 5:53 am
