So I recently bought a MacBook Pro 2.6GHz, but whatever I try I can't move.
I have particularly these problems:
- External controls with Hercules RMX doesn't work
- Serato interface doesn't work
Does anyone know fixes for these problems?
Posted Thu 03 Jul 08 @ 2:39 am
For the RMX you have to use the version 5.0.8
For the Serato sound card, it's impossible to use it on MAC because the box is locked
Posted Thu 03 Jul 08 @ 4:46 am
Also u can download the latest driver for the rmx if u haven't;)
Posted Thu 03 Jul 08 @ 5:54 am
The RMX works itself, but not with the external vinyl controls.
I can't work without ext vinyl controls:-(
Posted Thu 03 Jul 08 @ 10:00 am
Unfortunately, time code doesn't work well on Mac. You need Numarks Virtual Vinyl sound interface. I've also been told the Hercules MK2 controller works with time code. Since the MK2 works with time code I asked the question about the RMX, and was told it doesn't work with time code. The magical and mysterious VDJ ver 5.1 is supposed to address time code issues. VDJ is currently looking for beta testers for 5.1, so hopefully the wait is almost over.
Posted Thu 03 Jul 08 @ 2:24 pm
