Numark Cue 5.07
Windows XP Pro - SP3
Dell System - P4 3Ghz
1 Gig ram (2.99 Ghz)
Suddenly, and for no apparent reasn, my sound effects are gone.
When I click on the tab it list all the effects I have installed but when I click on them the control window is blink. Clicking on some of them cause a crash. They only exception is the Flippin Double effect which seems to operate as normal.
I tried installing some new effects and they too show up but fail to work.
I have uninstalled Cue, deleted all folders and registry entries and clean installed twice. Didn't solve my problem.
Any help would be appreciated.
mao
mao
Posted Sat 28 Jun 08 @ 8:58 pm
Can you please confirm that the DLL files are present in the Effects folder and your account has the correct permission to open them.
Do the files still have the correct .dll extension , on them (if not they will not be loaded).
Please also try deleting plugin.ini
Kind Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Kind Regards
Simon Bangs
Skype : NumarkSi
Posted Sun 29 Jun 08 @ 2:17 pm
Can you post here the data of your "crashguard report.txt" file
Posted Sun 29 Jun 08 @ 3:59 pm
All effects are in the correct folders and have extentions still intact.
NO "plugins.ini" file on my computer
Is that bad?
Still no effects.
Is that bad?
Still no effects.
Posted Tue 01 Jul 08 @ 5:35 am
bump for a solution
Posted Thu 03 Jul 08 @ 1:51 am
Probably you have already checked this.
I've all my sound effects in this folder
"C:/Documents and Settings/My_name/Documents/VirtualDJ/Plugins/SoundEffect"
but I saw you have got Numark Cue not VirtualDJ so you should check about it into another folder.
Have you tried to install the latest version of DirectX??
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3
Let's keep in touch to confirm any news about it
Posted Thu 03 Jul 08 @ 5:20 am
To understand this further could you please post this it is located in My Documents /numarkcue
Best Regards
__________________
Simon Bangs
Computer DJ/VJ product Specialist.
Posted Sun 06 Jul 08 @ 7:49 am
