Hey, i am using the hercules dj console mk2 for a while now but since recently virtual dj sais "Error in the asio sound driver" when i start it and it wont play a song.
The sound setup in the settings is as following
Inputs: None
Outputs: Headphones
Sound Card: DJ Console MK2
Output Channels: Master: Chan 1&2 / Headphones: Chan 3&4
Also when i try to enable the DJ Console sound card in asio4all it says the output is unavailable (With a red cross through it)
How do i fix this?
Thanks for your time, Lars
Inputs: None
Outputs: Headphones
How do i fix this?
Posted Sat 28 Jun 08 @ 7:57 am
Which version u using?
Posted Sat 28 Jun 08 @ 8:29 am
I am using the newest proffesional trial, but somehow everything works again :S
So problem solved(Somehow).
Posted Sat 28 Jun 08 @ 8:54 am
It's back it seems fixed after reboot but comes back after using of fl studio with asio4all
Posted Sat 28 Jun 08 @ 9:19 am
OK. Check at the herc control panel n see if that set to asio rather than wdm.
Posted Sat 28 Jun 08 @ 5:52 pm
It's set at wdm but if i set it to asio and start virtualdj it resets it to wdm
Posted Sun 29 Jun 08 @ 11:17 am
Leave the herc panel open , set to asio , then open vdj.. after setting, then just close the herc panel.
Posted Sun 29 Jun 08 @ 1:47 pm
You beat me there spinnaJ :)
Posted Sun 29 Jun 08 @ 1:55 pm
Hehe;)
Posted Sun 29 Jun 08 @ 4:26 pm
Ok it works now gonna try to install asio4all again when i get back from school to see what it does then
Posted Mon 30 Jun 08 @ 12:27 am
Hi lars, glad it worked out for u..
Just an advice, refrain from using asio4all if not necessary.
If u like the program after ur trial, pls support its development by purchasing it which u could with a discount;)
Hope to see u with us soon.
Posted Mon 30 Jun 08 @ 3:38 am
Well i need asio4all to emulate zero-latency for fl studio, but the weird part is first they worked perfectly together and i could use the djconsole as the sound card for asio4all now it sais unavailable when i try to select it.
And about buying it i can't i just don't have the money, and if i had it i would spend it on something else like new computer monitors
Posted Mon 30 Jun 08 @ 8:24 am
