Forum: Old versions
Topic: VDJ 4.08 and 4.1 sound card option???
I've been using the Xponent with VDJ 4.07 and just recently updated it to 4.08 but I noticed that the 4.1 sound card option in sound setup is no longer available.
What is the correct sound card setting I should be using or should I just revert back to 4.07? I know the option is there under windows 5.1...what happened?
Posted Thu 26 Jun 08 @ 10:43 am
Hi mikcer,
V5.08 main fix is from Herc rmx le migration to Pro version and not much improvement than the earlier version.
And there no need to use V5.08 if u don't use the rmx. I still on V5.07 too;)
I would advised do revert back to V5.07 if that been werking well for you.
Regards.
I don't have that file anymore and it's not available for download. Can anyone send it to me? PM me for my email address.
Hi mikcer, go to ur download center n grab it at there.. it should be there;)
Contact support n ask them for earlier version n y u need it;)
