I use a 500gb external hard drive, ever since purchase, Windows has assigned the letter G: to that drive. I was going out to Ibiza last week to DJ, I didn't want to take my 500gb drive because my gigs were audio only and I didn't need the Videos and also to minimise weight, space, etc. So, I decided to use a 16gb flash drive instead. On testing at home I installed the flash drive to the same USB port I normally use for the USB hard drive. Windows assigned the letter E: to the flash drive.
Later when I went to my residency just before leaving for Ibiza, I plugged my hard drive in and to my horror Windows assigned the letter E: to my external hard drive. The problem with this was all my playlists were useless as they were pointing at the drive letter G: I couldn't remember how to reassign a drive letter so my workaround was to unplug the hard drive and plug into other USB ports two flash drives (E: & F:) then plug in the hard drive last (G:), which worked.
When in Ibiza I avoided plugging the flash drive into the USB port that I normally use the external hard drive on to avoid drive letter changes to that port. Does Windows retain that last drive letter used? I don't know.
On returning from Ibiza my hard drive is back to drive G: when I plug it in. I've checked up on changing drive letters and stored a text file on the gig computer in case I need it again. I'm wondering is there some simple way to change the drive letters in the playlists, or, am I going to be stuck with making sure the drive letter is always G: ?
Posted Thu 26 Jun 08 @ 3:44 am
The playlist file .m3u is not dynamic as it doesn't update the drive.
It would be a good idea to write a batch file with an autorun
Posted Thu 26 Jun 08 @ 6:53 am
There is a fairly simple way of changing drive letters in a playlist file. Open the file in notepad, and use the find/replace feature. For example, you can set it to search the file for any occurrance of "E:/tunes" and automatically change it to "G:/tunes"....
Alternatively, you can change the letter that windows has assigned to a drive. Go into control panel - administrative tools - computer management, and go to the disk management screen. Here you can select the drive in question, right-click it and select the option to change the drive letter.
Hope this helps!
Hope this helps!
Posted Thu 26 Jun 08 @ 8:02 am
[djsherz]
"There is a fairly simple way of changing drive letters in a playlist file. Open the file in notepad, and use the find/replace feature. For example, you can set it to search the file for any occurrance of "E:/tunes" and automatically change it to "G:/tunes"...."
Only problem with this is if you have lots of playlists, could be quite time consuming.
Maybe in future versions of the program a playlist option could be implemented to 'relocate' missing files as they have in Traktor.
Posted Thu 26 Jun 08 @ 1:15 pm
Probably easier just to manually change your drive letter then, only takes a min... :-)
I've stopped using playlists altogether now in favour of virtual folders - unlike a playlist, they're not dependent on keeping the same drive letter.
Posted Thu 26 Jun 08 @ 5:31 pm
Hmmm, never really looked at Virtual Folders. Will have to look into them now...........
Posted Fri 27 Jun 08 @ 3:14 am
I noticed the main database doesn't care what the drive letter is, even though it's in the xml file.
Are the virtual folders stored on the external drive? I know the filter folders are stored on the computer itself.
Which things are dependent on drive letters?
So far I know this:
Dependent on drive letter:
play lists (stored on computer)
Not dependent on drive letter:
main database (stored on ext. drive)
virtual folders (stored on ?)
filter folders (stored on computer)
Thanks!
So far I know this:
Thanks!
Posted Mon 30 Jun 08 @ 6:20 pm
Static filepath for .mu3
Dynamic filepath for .xml
Favorite, Virtual and Filter folders are stored in the database
Posted Tue 01 Jul 08 @ 3:57 am
Virtual and filter folders are stored in the database
When you say dynamic filepath for .xml what exactly do you mean? I know the filepaths inside the xml state "f:" (for instance). However, when I connect the drive as g:, Cue still finds my song files. Is this because Cue looks at f: and doesn't see anything so it tries other drives or does Cue rewrite the .xml and change the paths to g: instead of f: or does Cue ignore the drive letter and automatically use the drive letter that the drive is currently using (so it automatically knows to replace every f: with g:)???
And yes, filter folders are stored in the database, but I found them in the database stored on the computer, not in the database stored on my ext. drive.
I'm just trying to see what I have to watch out for if my drive changes letters and where I find my custom folders when I want to copy some from one system to another.
A nice list of where all special folders are stored and which folders/playlists/databases need the proper drive letter would be REAL useful :) That's something I'd like to add to the wiki ;)
Thanks!
Posted Tue 01 Jul 08 @ 1:25 pm
Any more info DJ Cel???
Posted Wed 09 Jul 08 @ 12:18 pm
