Hi all ive just brought the mk 2 console and i am ruunning it on virtual dj pro 5. but i have a really weird problem.
whe i play a tune on deck a i will be able to here what is playin on deck b for some reason and visa versa.
Cane any1 help as this is really annoying now??
thanx
Turbo
thanx
Turbo
Posted Tue 24 Jun 08 @ 3:55 pm
1) Double posts are annoying
2) Search button does function... This has been discussed and resolved.
http://www.virtualdj.com/forums/91281/PC_Version_Technical_Support/Problem_with_MK2_not_using_channels_correctly_-_Solution.html?highlight=MK2
Posted Tue 24 Jun 08 @ 9:29 pm
yes i have done this already but still hasnt worked.
Posted Wed 25 Jun 08 @ 4:22 am
Posted Wed 25 Jun 08 @ 4:46 am
Have you upgraded to 5.1?
Posted Fri 27 Jun 08 @ 4:06 am
