Sorry if this has been asked before........ A fellow DJ asked me how does VDJ intergrate MIC support, when broadcasting (shoutcast) and recording? As I do not use a mic myself, I haven't any suggestions...... Is it as easy as just selecting 'Master + MIC', then selecting the desired mic/device in the drop-down menu?
Also, will there be any support in the future to be able to record while your broadcasting?
TIA
TIA
Posted Tue 24 Jun 08 @ 5:43 am
Yes, Peter, in the broadcast config menu there is an option for selecting the mic. Also, use a skin with a mic volume control on it. When he is done talking I would use the PC's system mute as opposed to the mic volume adjustment on the skin. PM me if you have any more questions...T
Posted Tue 24 Jun 08 @ 7:48 am
