A couple of the Skins I use haven't got a unload button, so in Rev7 I created Keyboard shortcut.
END key unloads the deck I've just played. (END = Unload, default Deck), it worked fine.
Now in 5.1 I've noticed the shortcut only sorts of works on one deck, the left side. If I try to unload the right deck after I've played it with this short cut, it ask me whether I want to stop the music, but the track is finished with.
Could someone is tell me is this right, as it's doin my head in, or can some try it, and see I haven't got this wrap around my head.
Posted Mon 23 Jun 08 @ 10:37 pm
Nope, it certainly don't want to play ball and behave like it did with Rev7.
Abit pissed off now.
Posted Tue 24 Jun 08 @ 11:43 am
Are you using timecode and is the cue light staying on after you press stop? If it is, this is something to do with the timecode setup. If I use autoconfig for the timecode setup, the cue light will stay on after the deck has been stopped and I cant load tracks without getting that message that the track is still playing. If I reset to factory settings and just manually adjust the gain in timecode setup, it works great - could be something to do with the silence setting?
Posted Wed 25 Jun 08 @ 3:41 am
Cheer's musicalcheers, I will check next time I spin.
Posted Wed 25 Jun 08 @ 8:29 am
Last time I had a pissed Jimmy I had to see my doctor and get a shot......
Posted Wed 25 Jun 08 @ 1:55 pm
