Can someone explain to me how can I make My Macbook Pro running on 10.5.3 to work with Hercules RMX console?
It says error in sound driver as I try to start it.
Tnx
Tnx
Posted Mon 23 Jun 08 @ 11:58 am
Have you downloaded the 2008 driver from the Hercules support site this will resolve this.
Posted Mon 23 Jun 08 @ 12:33 pm
Check that you have selected the right sound card, and in first time, the RMX it's working with the RMX Control Panel.
An advice. Plug the RMX in the right USB, not in the left.
I was experiencing the same problem as you.
Good luck.
Good luck.
Posted Mon 23 Jun 08 @ 1:34 pm
That fixed the problem. Unbelievable.
Thanx:)
Posted Mon 23 Jun 08 @ 2:22 pm
If that fixed it your os may be out of date as these ports have issues on earlier firmwares for the usb.
Posted Mon 23 Jun 08 @ 2:24 pm
Huh, I have my MacBook Pro like about 3 weeks now.
It came with 10.5.2, so I updated to 10.5.3.
Don't see how can it be out of date?
Anyway, must admit, this is my 1st mac. Was on PC earlier..
Posted Mon 23 Jun 08 @ 2:33 pm
Might want to run another update to be sure.
Macs tend to have a couple of months of sitting in a warehouse.
Posted Mon 23 Jun 08 @ 3:20 pm
I'm not the only one that have notice this bug in macbook pro.
I have read a few weeks ago, another user has the same problem.
My OS it's up to date, and the firmware it's the lastest.
I don't know why, but that's the solution.
Best mixes for you all!!
Posted Mon 23 Jun 08 @ 5:23 pm
