Forum: Old versions
Topic: headphones problem
I got the Rmx and Virtual Dj 5.1 when I tried to use the headphones cueing, I can't hear anything on my headphones. My setting is input is none, output is single, and soundcard is the Rmx. I tried to do the second output with the speaker and headphones, I can hear both deck playing at the same time even though the fader is on Deck A and heaphones don't cue the right deck either. please help!!!
Another question, how come when I just the volume on the Rmx, there is a popping sound. please help!!
Posted Sun 22 Jun 08 @ 11:02 pm
First of all.... should register your stuff.
Now, I am going to assume you downloaded the newest drivers for the RMX right?
Now, go into Config--->Sound Setup--->Outputs--->Headphones
Soundcards--->RMX
Set your outputs to Channel 3/4 Main and Channel 1/2 Headphones. Click OK
Now go back in and set it correctly (Channel 1/2 Main 3/4 Headphones)
i will try that, how do u fix the popping sound when i adjust the volume or the jog wheel, thanks a lot
