I have the Pro Edition of VDJ and i want to know how do i use the Hercules Mk2Console with the Pro version?
Posted Sat 21 Jun 08 @ 8:22 pm
Plug and play:)
If it doesn't work, check in config>remote control and make sure it's enabled. You should also get the most recent drivers from Hercules - they make the MK2 work much better with the newer VDJ versions ;)
Posted Wed 25 Jun 08 @ 11:03 pm
