While mixing earlier today I noticed that if I move the crossfader a hair off the center line it completely mutes the song playing on the opposite deck. For example if I have a song on deck a and i start to mix a song on deck b if I move the cross fader towards deck b i will stop playing sound from deck a and vice versa. any help would be apprectiated it.
Thanks,
Pete
Thanks,
Pete
Posted Tue 17 Jun 08 @ 5:37 pm
go to config - option - crossfader and select full this will change the behavior of the crossfader
Posted Wed 18 Jun 08 @ 6:54 pm
