I have a question, I mainly make mixtapes all the time. And the only problem i have is when i change tracks there is a break in the mix when i go to track2 for example. is there any body who can tell how to make my whole cd stream smoothly together where there is no break every time the track changes. any tips will be highly appreciated.
DJ SLUR
DJ SLUR
Posted Tue 17 Jun 08 @ 3:18 pm
What are you recording to, cd recorder, dvd recorder, hard drive, tape?
Posted Tue 17 Jun 08 @ 3:31 pm
Make sure you do not have split selected in the record config set up
Posted Tue 17 Jun 08 @ 3:44 pm
