Hi guys,
Here's my setup:
BCD2000+Vdj5r6+3.3mapper+Vista
While I am playing with my BCD2000 for about an hour it will suddenly freeze and I nid to close the virtual dj 5r6 and open again to be able to run again the music, even when i click the play button in virtual dj still it won't play so i need to close the application and start again.
I followed the instruction in 3.3 mapper and used the new Behringer driver.
Do I need some tweak on my Vista or configuration in virtual dj?
I hope you can help me with my concern.
Thanks.
Here's my setup:
Thanks.
Posted Tue 17 Jun 08 @ 10:19 am
We would suggest trying the demo version of the software in which the controller is supported fully.
Not sure where a non licensed user would get a mapper, but the fact that you are also not using a current version leaves many possibilities open for the troubles you are having.
If you do this the right way, you will find many people willing to help you with problems you may encounter.
Posted Tue 17 Jun 08 @ 11:05 am
Thanks.... My friend let me try to use his mapper... Now I will try to download the new version... then buy if it is fully working.... Thanks.... I will update you soon!
Posted Thu 19 Jun 08 @ 2:41 pm
