On Saturday 14th of June I arrived at a bar to mix, i clicked on the icon to open VDJ i took a long time open then it said problems with the "sound engine" then when i put a song to play it do not want to play it then i went to click on the Config button VDJ froze so i Ctrl/alt/del then i reopened it same thing, it took me an hour to play and the morning after it did not even work.
how can i fix this
how can i fix this
Posted Sun 15 Jun 08 @ 7:06 pm
Can you post here a screenshot of this message.
Posted Mon 16 Jun 08 @ 5:42 am
