Ok heres whats been happening, over the last couple of weeks i've been fixing about 10,000 song titles and artest in Vdj data base because they were mixed up after swiching to version 5.1 . Now I have an even bigger problem, how do i go about printing all the info i.e (Artest) (Song title) onto Karaoke books Can anybody help me please.
Thanx Djmart
Thanx Djmart
Posted Wed 11 Jun 08 @ 7:26 am
you will have to get external software something like "karaoke song list maker" www.airwer.com has a limited free to try but maybe best to put a google out, there's quite a few out there and it just means you shopping about for whats best for your needs and best deal
Posted Wed 11 Jun 08 @ 7:47 am
Hi...you could try this website which provides a free to try program for writing song books for you...otherwise put a search on google for 'karaoke song book writer' or something like that...
P
P
Posted Wed 11 Jun 08 @ 7:56 am
Ooooh....looks like you made it before me mate...hehehe...:o)
How's tricks?
P
How's tricks?
P
Posted Wed 11 Jun 08 @ 7:57 am
great thanks and you, still working yourself to an early meeting with your maker... lol
Posted Wed 11 Jun 08 @ 8:22 am
the very best program i have found for making books either for karaoke or mp3's....is called song list generator
it is for a fact awesome.....hope this helps...
Posted Wed 11 Jun 08 @ 8:44 am
I use K-Books for both my Karaoke & Videos..find here: http://www.k-books.net
Posted Wed 11 Jun 08 @ 1:23 pm
Having used Airwer for many years i can with no doubt say its the easiest and best software available for Karaoke books.
Posted Wed 11 Jun 08 @ 2:10 pm
Hehehe...just trying to make the old ends meet mate. You know how it is.
Too much work and not enough dj's when i need them...and then not enough work when i want it!!!
Man, i love this job!!!
Posted Thu 12 Jun 08 @ 6:25 pm
OK team thanx for the sites, sorrs bout the late reply...... Ive tried a few diff program's and the problem i have now is that half of my collection have the name of the cd and track ( ie CDG+G 1204 Track 11 ) etc etc think i'm stuck changing all names in vdj data base. .................... any more help going ????
Thanx
Djmart
Thanx
Djmart
Posted Mon 11 Aug 08 @ 12:27 pm
you should be able to select which fields you want to display on your print out list, check again, in the mean time if you could tell us which software you are actually using please.
Posted Mon 11 Aug 08 @ 1:45 pm
I don't think you have to change everything around manually in VDJ; there is an easier way. If your files are zipped, you can get a copy of MP3Toolz.NET 4 (free), unzip them all and edit them in Tag&Rename (not real expensive), get the tags right if they are backward (the software has a "swap artist and title" option), then choose a naming scheme (or create one, I use disc#-track# - title - artist.mp3), rename the files (Tag&Rename also updates the .cdg file with the same name automatically), and zip them back up (be sure and set the compression in MP3Toolz.NET to "5-Default compression," or they won't work in VDJ!!).
EDIT: I just remembered...If you're in a pinch for a quick list, you can export the information from Tag&Rename as a .csv file, import into Excel, sort the way you want, then print a list from there ;)
Posted Mon 11 Aug 08 @ 4:22 pm
doc, thats an awful long way about when the software will do that for him all he has to select is the fields he wants in his print out
Posted Mon 11 Aug 08 @ 5:46 pm
WHOA STOP!!!! You guys didnt see that he was fixing these files within VDJ, That DOES NOT change the TAGS, so now the work he did will NOT show up on any software he uses to make his books as they are in the VDJ DATABASE!!!!
You need to change the names on the FILES THEMSELVES outside of VDJ.
Posted Mon 11 Aug 08 @ 6:12 pm
That's one of the reasons I suggested the Tag&Rename method above, Brian...I agree. It would be an awful shame to do all that work only to risk losing it to a database problem. It should be done outside of VDJ, certainly. I've spent a lot of time getting everything right in the tags themselves in order to prevent possible issues - so far, so good ;)
EDIT: Perhaps I should have said "better" rather than "easier" hehe.
Posted Mon 11 Aug 08 @ 7:18 pm
Thanx you guy's and gal's youve been a real help i'l get there some how i will try tag&rename
peace
Djmart
peace
Djmart
Posted Wed 13 Aug 08 @ 6:34 pm
Good luck; I'm sure you'll make it ;)
Take some time to explore the features of Tag&Rename. It's pretty powerful software. I couldn't do without it now, lol.
Posted Wed 13 Aug 08 @ 9:53 pm
song list generator for books it removes duplicates out of the book after it scans your hd for all of the files you have...and a renamer on the same site is kj file manager...cost of each only $79.00...but the best part is they actually work
www.latshawsystems.com
Posted Thu 14 Aug 08 @ 5:22 pm
