Hi all, I'm just a new user of Virtual dj, program has been installed, look seem all ok, but the effects have problem, clipbank just empty,and i try to load from window to look for it from / plugin file/video effects/ but nothing to found, i also go to website to download plugin , it call Clipbank v1.2, open that file and install / i reopen Virtual Dj again to check is it work,... but it still the same problem,
So please is anyones get more pc skill to help me w this
thank a lot everybody
Posted Mon 09 Jun 08 @ 3:02 am
This isn't a bug, you must install clips into the clip bank...It is just a container that does not come with its own clips. Click on one of the empty squares in the clip bank to load a clip. You can find information about some sample clips by doing a forum search. Good luck ;)
Posted Mon 09 Jun 08 @ 4:40 pm
