I have a couple sound effects that I put under the Soundeffect folder under the VirtualDJ folder. They are .dll if that matters. However none of them show up under the sound effects menu in virtual dj.
Posted Sun 08 Jun 08 @ 3:03 am
Can you give some examples of plugin names
Posted Sun 08 Jun 08 @ 12:36 pm
DJCorpse_Flanger.dll
FlippinDouble.dll
also do you know how to start both songs at the same time?
FlippinDouble.dll
Posted Sun 08 Jun 08 @ 5:51 pm
Where did you obtain the plugins, what versions are they, and what version of Virtual DJ are you using? The Flipping Double effect is supplied by default with Virtual DJ Professional.
Starting both decks at the same time can be done by creating a keyboard shortcut to perform a play action (eg play_pause). Add the shortcut twice with the same key, specifying a different deck each time.
Posted Sun 08 Jun 08 @ 7:02 pm
I believe the versions are 5.0? I'm using 5.1
Posted Sun 08 Jun 08 @ 7:34 pm
http://www.virtualdj.com/buy/
Posted Mon 09 Jun 08 @ 6:04 am
