With the same information that was posted earlier in the thread.
Posted Tue 03 Jun 08 @ 3:53 pm
The first thing I noticed after the record video feature (Very cool and much desired by the way), was the video brightness is adjusted with the mixer volume, very nice.
I'm sure there is a way to turn this feature on and off. As cool as it is, there are times I'll want it off too. (I'll find the answer)
Posted Tue 03 Jun 08 @ 6:56 pm
Found it:P
Again, very cool feature!
Posted Tue 03 Jun 08 @ 6:58 pm
djcel wrote :
Better to use the install file:
http://www.undercut.org/msmpeg4/
Dlls are not enough because Windows need data in its registry
When I did this I got a Windows message that said this may cause Windows to become unstable and to insert my Service Pack 3 CD to uninstall it. I just auto updated windows which is where I got SP3 from.
Should I be concerned???
Posted Tue 03 Jun 08 @ 7:02 pm
sclavel wrote :
Timecode:
- new engine "VDJ Timecode v5" for VirtualDJ vinyls, optimized for scratch (the old engine "VDJ Timecode v4" optimized for needledrop is still available)
- new engine "Noisemap" compatible with most noisemap-based records
- new engine "PCDJ" compatible with most miss pinky-based timecode records
Timecode:
So that does mean that we "beatmatch only" DJs should use the "old" V4 engine for sure ?
And what are "noisemap" records pls ? ;)
Posted Tue 03 Jun 08 @ 8:49 pm
For example, Serato Scratch Live vinyl or CD
Posted Tue 03 Jun 08 @ 9:11 pm
djcel wrote :
For example, Serato Scratch live vinyl or CD
Ah, thanks DJCel !
And now tell me which of them are the best for "beatmatch" DJs ? ;)
Or is the timecode tracking/reading just up to the VDJ engine ?
Was there any change/improvement to the "old" V4 engine ?
Posted Tue 03 Jun 08 @ 9:12 pm
I really like this new version.
I had ordered a Pinnicle Movie box plus (usb capture device), I had another Capture Device on my home computer but it wasn't VISTA compatible. So I got another one. Installed the software/drivers and hooked up a run of the mill Sony Handycam Started VDJ & started the camera plugin.
CHose my USB device as the "camera" and activated.
There was my video camera image on my extended monitor. Smooth tracking and picture quality.
VERY NICE DEV TEAM!!!!
the New BPM/ key signature detection is fairly good.
Posted Tue 03 Jun 08 @ 10:09 pm
Serato vinyls are a go.......and for 10 dollars, the transparent yellow ones are a must!!!!! Can't wait for vdj fancy vinyls...yeah.
Posted Tue 03 Jun 08 @ 11:09 pm
I can't see it happening soon, I would love to see it though, but I don't think there is a big demand for them yet.
There was that thread started last year about them, it was quite a good one aswell.
Posted Tue 03 Jun 08 @ 11:20 pm
tomorrow..me ...guitar center...serato vinyl....even though i got vdj timecodes already..jus for the phuck of it..ima get some BLUE vinyls..if they have em ..lol..and take pictures..and BE HAPPPPPY>>>.
thnx dev team ..yall realllly hit home with this update...no wonder yall tooook so long..thnx AGAIN!!!
Posted Wed 04 Jun 08 @ 12:47 am
um... there i was thinkin i was recording a mix when i finish up and see ***record error*** - can not change resolution while recording?
arrrrgh. and i was having fun too.
and here i thought i had that codec thing whipped.
Posted Wed 04 Jun 08 @ 2:18 am
so after a few smokes, i had an idea for 5.1.01 - a column/field that lists the videos resolution just like it lists artist/bpm/bitrate etc...
is this do-able? among other things it would help control quality of the output if you have to play videos that have different screen resolutions.
just a thought.
just a thought.
Posted Wed 04 Jun 08 @ 2:55 am
I have seen references to a new updated manual for 5.1 but can't seem to find it anywhere (the site just has the 5.0 manual posted for download).....anybody know where to get the 5.1 manual
Posted Wed 04 Jun 08 @ 8:13 am
you wont find any..........if you do let me know!!!!!!!!!!!!
Posted Wed 04 Jun 08 @ 8:21 am
as anybody seen the Red Serato Vinyls, lovin them.
VirtualDJ really does need some coloured vinyls.
Posted Wed 04 Jun 08 @ 8:51 am
start menu/programfiles/vdj/manual.......;)(comes wit tha download/upgrade)
Posted Wed 04 Jun 08 @ 8:54 am
dj t boogie wrote :
start menu/programfiles/vdj/manuel.......;)(comes wit tha download/upgrade
You can also find the manual on the new wiki - VDJPedia -> Community link above -> Click on Wiki
Posted Wed 04 Jun 08 @ 8:57 am
Only offered online or 'an authorised distributor'...e.g
http://www.platinum-records.com/Rane-Serato-Scratch-Live-Blue-Colored-Control-Vinyl-prod7778.htm
red.
http://www.proaudiolab.net/index.php?act=viewProd&productId=26
Posted Wed 04 Jun 08 @ 10:36 am
lol L2...i found some......
http://www.pssl.com/Rane-Scratch-Live-Time-Coded-Vinyl-Blue
ahaha..man i shouldve bet on that..lol
Posted Wed 04 Jun 08 @ 11:07 am
