Topic: help on skin
ive just re installed vdj and i used to use the default advanced skin. but this time its not there. just the default basic one.
does anyone know where to get the advanced one from.
i checked the skins downloads page but couldnt find it there either
Posted Fri 31 Dec 04 @ 8:50 am
you tried changing skins in vdj?
yeah mate but for some reason the advance skin is not listed
try this skin, not sure how much like the default it is but looks similar skin
its happend to me before, just re-install the program
he says he has tried that but it should work
it's in the download list .. but you have to click on "show all submissions".
thank for your help guys. yeah i found it in the skin downloads now. i never even saw the 'show all submisions' tab before . thanks
PJay
