If you connect CDJ's( like the Denon 3500) to the Hercules MK2 are you still able to use features from the cdj like the effects, loops, etc.
Posted Wed 28 May 08 @ 2:16 pm
Only if you're using regular cd's, loop in & out will probably still work with timecodes but for effects you'd have to either use effects in VDJ or put an external effects processor between the mk2 outs & your mixers ins;^]
Posted Wed 28 May 08 @ 2:22 pm
