Strange,
It doesn't matter wich skin I use but all the skins doesn't maximize at all.
Strange, because yesterday I didn't had that problem with the skins.
Does somebody knows what's going on?
Posted Wed 28 May 08 @ 1:58 am
What you really wanna do is get a skin that matches your screen resolution and run it in Window mode, ie. I use Video Vision that is 1280X768 and my screen resolution is 1280X768. This allows me to minimize without issues. If you maximize and ur usin a different resolution u may run into issues and not be able to get vdj back up.
Posted Wed 28 May 08 @ 3:32 am
Discobrain24,
I always use DN-S3500 Suggestion skin.
But since yesterday it won't maximize.
Posted Wed 28 May 08 @ 3:48 am
Problem solved :
Change the resolution to of the background to 1200 instead of 1440 x 900.
Maximized the skin and automatically it went back to 1400 - 900 and the skin stays maximized.
Posted Wed 28 May 08 @ 6:49 am
I agree with Brian in that maximizing a skin from a lower resolution makes things look all loopy and wierd. It's better to have one designed around your resolution - it makes a big difference visually ;)
Posted Wed 28 May 08 @ 10:44 pm
Ok, I also agree but I don“t have a DN-S3500 Suggestion 1440 x 900 skin.
If somebody could make this for me, it would be great !!!
Posted Fri 30 May 08 @ 7:37 am
