I am not sure if my icdx's are up to date. I downloaded the firmware, but I can't seem to get them installed. Please help me with step by step instructions.
Regards,
Longside.
Regards,
Longside.
Posted Sat 24 May 08 @ 5:05 pm
This will help you update.
How To Create an iCDX Update CD:
1. Go to: http://www.numark.com/icdx
2. Click on, Documents & Downloads
3. Then, click on the link titled iCDX - Firmware Update [version 44] (8MB)
4. Once downloaded to your computer, uncompress the icdx_v44.zip file.
* The file you’ll download is a .zip file that needs to be un-zipped.
* Many computers come with a utility pre-installed to un-zip .zip files. Simply double-clicking on the .zip file will often open the utility and allow you to uncompress the file.
* If needed, you can download an un-zipping utility for the PC called WinRar at http://download.com
* Macintosh users of OSX or later can simply double-click the file to un-zip it.
* Once un-zipped, you’ll have an .iso file which needs to be burned as an ISO CDR. The file will be called iCDX_v44.iso
5. Burn an ISO formatted CD from the iCDX_v44.iso file
* Most CD burning programs cannot burn CDRs in ISO format.
* However on a Windows PC, you can download a free program for the PC that can burn ISO CDs at: http://www.burn4free.com
* This will allow you to burn the OS file to an ISO formatted CD-R disk.
1. When you launch Burn4Free for the first time, it will ask you if you want to open the program in Easy Mode or Expert Mode. Choose Expert Mode.
2. In Burn4Free, click on the icon that says Burn ISO. If you don’t see this icon, click on the View menu at the top of the screen and select Switch to Expert Mode. You should then see the Burn ISO icon.
3. You will be prompted to locate the .iso file to be burned to disk. Use this window to navigate to the iCDX_v44.iso file you downloaded, double-click it and then select Open.
* Macintosh Users can use the program Disk Utility to burn .ISO disks.
1. Open the Disk Utility which is located in the Utilities Folder inside your Applications folder.
2. Click on the Images menu at the top of the screen, and choose Burn
3. In the Select Image to Burn window that opens, navigate to the icdx_v1.18.iso file which you downloaded. Highlight it and click Burn
4. Insert a blank CD-R into your computer, and click Burn
* When you burn the disk, do so at the slowest speed possible. It is a small file, and won’t take long to burn.
How To Update An iCDX:
1. Power the iCDX on while holding down the [PROG] button.
2. The iCDX will display Prog Upgrade, No Disk
3. Insert the update disc. The iCDX will display Prog Upgrade CD Reading TOC as the disk is tested.
4. When the disk test is completed, the disk will automatically eject and the update will begin.
5. The iCDX will display Prog Upgrade, MCU Upgrade. The update's progress will be displayed in the upper right of the screen. When this number reaches 100 the iCDX will automatically restart.
Kind Regards
Simon Bangs
Numark Support.
Kind Regards
Simon Bangs
Numark Support.
Posted Sat 24 May 08 @ 5:31 pm
Thanks skyfxl,
I don't know if it is coincindence that you are always helping me, but you are by far the most helpful person so far. Keep up the good work.
Thanks a bunch,
Longside.
Thanks a bunch,
Longside.
Posted Sat 24 May 08 @ 6:47 pm
Your most welcome , i try to do my bit to help folks out :)
Posted Sat 24 May 08 @ 7:25 pm
