I have the Rane ttm57 mixer want to use vdj have connection problems mixer won't work also want to video mix do i need a controller for that also Have parties this weekend.
Posted Fri 23 May 08 @ 1:46 pm
I am not sure if it has MIDI option to be able to control VDJ.
Which version do you use?
Posted Fri 23 May 08 @ 2:00 pm
vdj 5.0 i need midi on the mixer it does not have it
Posted Fri 23 May 08 @ 2:02 pm
Check out this page:
http://www.virtualdj.com/products/hardware.html
or
http://www.virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html?page=1
You can find many mixers with MIDI option today.
or
Posted Fri 23 May 08 @ 2:39 pm
