EDIT
not sure what you mean
dose it split them up
2 cd decks go in to VV --- 4 phonos (2 left and 2 right) then from the box 2 time code come out and 2 for audio cds
Posted Mon 19 May 08 @ 12:33 pm
plug your decks into the line ins, for timecodes you run the outs to your mixer and for regular cds you run from the bypass ports to your mixer. Maybe somebody else can explain it better than me;^]
Posted Mon 19 May 08 @ 12:47 pm
A closer look at the back of the VV box.
Posted Mon 19 May 08 @ 12:55 pm
run from the bypass ports to your mixer do i have to unplug any thing
do i have to switch some thing to swap
i could do it with been set up so i can have 1 person on vdj and if the next dj wants to use the CDJs he can just go on them with out any bother
Posted Mon 19 May 08 @ 12:57 pm
thanks for that pic i have seen 2 vv boxes are they the same 1 is silver and looks different from the 1 pictured hear
i found 1 hear
decks.co.uk
i found 1 hear
decks.co.uk
Posted Mon 19 May 08 @ 12:59 pm
You will not have to unplug anything to switch, just switch using your mixer. As long as your mixer has 4 stereo line inputs you should be good to go.
Thanks Jimmy;^]
Posted Mon 19 May 08 @ 1:00 pm
ok thanks ya i have the DJM 800 and will it make things complicated if i wanted to have that as a controller
there are 2 Virtual Vinyl boxes out which is best to go for
thanks andy
thanks andy
Posted Mon 19 May 08 @ 1:14 pm
I don't think there is Andy, that one on the www.decks.co.uk website looks like a newer version of the one I posted, it will still have the some feature's as the older one, it's probably just a cosmetic change.
I think the Numark VV package will be ideal for you.
Posted Mon 19 May 08 @ 1:23 pm
