hi people. i am pretty new to Virtual DJ but when i use the slide controls, be it the crossfader or mid, treb etc i get a loud sort of crackling noise .Canb anyone help me sort out my preferences set up please ? in simple if at all possible lol.Cheers people.Wayne UK
Posted Fri 16 May 08 @ 9:54 am
Set the performances tab to the left, increase latency as your sound card cannot play at your current setting.
Posted Fri 16 May 08 @ 12:36 pm
What version are you using?
What equipment are using ( midi, controller, TTs ect. )
Are you using PC or Laptop?
Posted Fri 16 May 08 @ 12:37 pm
Just disable the "safe mode " option in the config
Posted Fri 16 May 08 @ 2:17 pm
Yep all the above post are right.
Disable the safe mode n put auto in latency n put the slider right to the fastest in the performance tab in config. Also u can try to disable the overclock.
Posted Fri 16 May 08 @ 5:25 pm
wow thanks guys, it's working pretty damn well now
Posted Sat 17 May 08 @ 2:36 pm
Glad u sorted it out.
Hope to see u with us soon;)
Posted Sat 17 May 08 @ 4:28 pm
