Hello there. Took delievery of my RMX this morning and gave it a little testing. One thing i noticed was that after about 4-8 bars of music, there was a split second loss of sound. It was pretty annoying. Is there anyway of getting rid of that.
And i might be a complete idiot, but i can't manage to get the faders to work. I've put the 'Monitior' knob to mix, but the faders don't respond at all. Any ideas. I was too use to the MK2, so this might take some time.
Cheers
Cheers
Posted Thu 15 May 08 @ 5:54 am
Managed to get the faders working, just changed the output channels, but i've still got the blips. Any ideas what settings to use in the performance tab?
Cheers
Cheers
Posted Thu 15 May 08 @ 8:56 am
Preset slider all the way to fastest, latency on Auto.
Posted Thu 15 May 08 @ 9:00 am
I tried this, but the blips still happen regulary. My laptops specs aren't bad so i dont think its that, but are there any other settings i could try?
Cheers.
Cheers.
Posted Sat 17 May 08 @ 12:32 pm
you could try this http://www.virtualdj.com/forums/90108/PC_Version_Technical_Support/Audio_Output_-_Slight_Pauses.html it may help
shame on you jimmy did we forget... to much shopping eh
Posted Sat 17 May 08 @ 12:37 pm
You might have problem with IRQ conflict, can you try using some other USB port? If you have some other USB devices like mouse or external hdd, try without them.
Posted Sun 18 May 08 @ 9:28 am
