Forum: Old versions
Topic: Problems after mixing for about 3 hours.. Play wont work!
I have a problem that often happens after 3-5 hours of mixing. Suddenly I can't make the second deck play! I can search the track and do everything without making it play! The first deck continue as normal but I cant mix in the second track. Somebody please help me!
Posted Tue 13 May 08 @ 12:56 pm
I am having almost the same problem the 1st deck is playing and when i try to add a song to the 2nd deck its almost likes it load but i can see the wave and if a try to re load it the program locks up any one with this issue????
Which sound card do you use?
