Forum: Music discussion
Topic: Help with using my headphones!
maduzaHome userMember since 2008
I want to use my headphones because it´s an important part of mixing. But it don´t work! Can someone tell me how to connect my headphones with VDJ? Maby my problem is my old-soundcard with only one connection? I need help very quick I hope someone will tell me about my problem! This are my institutions:
- Inputs: None
-Outputs: Headphones
-Soundcard(s): Mono Seperated
Posted Sat 10 May 08 @ 3:13 pm
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
This topic has been discussed many, many many times.....please utilize the search feature and you will find your answers there...
Posted Sat 10 May 08 @ 3:41 pm
71395Home userMember since 2008
yo dude il do the best i cn to help yu .... as u said it yoself the problem is your sound card with one output slot .... so i sujest u get yourself a new n better sound card or u cud use two sound cards with single output slots .... one for the earphones and one for sound output....adjust yo card configuration n ul be on ya way !!.. gud luck
Posted Wed 14 May 08 @ 5:11 am
