VirtualDJ 5.0.7 freezes when activate the Sonique Effects. I installed the most recent video card drivers and K-Lite Codecs version 3.90 but the problem continues. I need to close it with the task manager.
I tried with the Hercules MK2, Total Control with IO or the internal sound card.
Any ideas?
Thanks
Any ideas?
Thanks
Posted Mon 05 May 08 @ 8:13 am
Which graphics card do you use?
Posted Mon 05 May 08 @ 9:05 am
How old is the Sonique visual pac? The latest has removed some of the problem files.
Posted Mon 05 May 08 @ 1:19 pm
I installed this: Sonique Visual plugins certified by djcel Date added: Mon 28 Jan 08 but i don't remember that the old sonique effects was removed first.
I will try to remove all sonique effects and then install the Sonique Visual plugins certified by djcel again.
The laptop video card is Ati Mobility Radeon x2300
Posted Mon 05 May 08 @ 2:14 pm
