Can anyone help I am receiving a message that says a "USB device has exceeded the power limits of its hub port." Its funny that when I plug the RMX into my HP labtop it works fine. I am installing the software when this message pops up. But when I tried two different computer it had given me the above message. Has anyone else had this issue?
Posted Sat 03 May 08 @ 5:42 pm
pmel
make sure the rmx is plugged in to the usb port first before you boot up your lappy, if that doesn't cure it you may have to consider buying a powered usb to make your connections...
Posted Sun 04 May 08 @ 5:26 am
