Hi All,
I want to copy my cue points and stuff over from my main pc to my laptop. what's the best way of going about it?
Thanks in advance.
Thanks in advance.
Posted Sat 03 May 08 @ 9:55 am
Are you using an external hard drive? If not copy the database .xml file onto a mobile device, like a thumb drive, and simply place it in the same folder on the laptop as you found it on your desktop. My Documents>VirtualDJ>VirtualDJ Database.xml + VirtualDJ DatabaseV5.xml files
Posted Sat 03 May 08 @ 10:06 am
Hi thanks for the reply. I'm using an external on the desk top but an internal on the laptop. will the differing paths make a difference?
Posted Sat 03 May 08 @ 10:10 am
No, but..the external has a database.xml file on it..If I were you I would bring the external and use it with the laptop...VDJ runs very well if it can dedicate one drive to the music and one drive to operating the software.
Posted Sat 03 May 08 @ 10:27 am
Use your external, everything you need is there,
You then don't have to fart around moving and copying things.
Posted Sat 03 May 08 @ 10:39 am
Thanks guys but that was how I'd head out before. With the external but I don't want to leave the house with all my data. the laptop copy acts as a back up, so it wont matter if something goes wrong or it gets stolen etc.
The file VDJ stores on the ext hdd, can that be copied over?
Thanks for your help guys
Posted Sat 03 May 08 @ 10:47 am
