My first night with MK3 RMX when okay except for when the song continued to run after the song was over, No it didn’t repeat, the timer and the deck kept playing until I manually stopped it. The sound had a little skip about every 3 minutes and I could find a solution.
Posted Fri 02 May 08 @ 12:11 am
I just set up my laptop case and the time and decks still continue to run after the song ends.
Posted Fri 02 May 08 @ 1:35 am
DJ-ALF wrote :
I said it might be a bug, it is not confirmed yet. Try to find some other user that has RMX also and see if it has the same problems.
Thanks I'll ask around but I can see another BCD2000.
Posted Sat 03 May 08 @ 7:53 am
Hope not ;)
Posted Sat 03 May 08 @ 8:40 am
