Anybody having problems with text 2d plug-in? For whatever reason I am getting random VDJ crashes when I use this plug-in. It will work fine for about 3 hours but then it will just crash the program.....never have a crash when not using the plug-in and everytime I have used it for more than 3 hours I have a crash.....always crashes after about 3 hours, don't know if the time is significant or not but any show I have done under 3 hours has never crashed either.
Anybody else? Any known cause, conflicts and/or fixes?
Posted Mon 28 Apr 08 @ 10:26 pm
weird. I use for hours on end running continuesly and it doesn't crash.
But I keep it simple by making it the ONLY video effect running the whole time.
Posted Mon 28 Apr 08 @ 10:47 pm
Has it always acted this way, or did it just start? What machine are you using? Have you made any changes to the machine. I also use this all day, with other effects, without issue.
Posted Tue 29 Apr 08 @ 3:22 am
I just started using it st patricks day and have used it on 3 shows that lasted 4 hours and all three times it crashed shortly after 3 hours. I have used it several times on shorter 1 and 2 hour sets with no problem. The machine is an amd64x2 4200+ with 2 gig ram, nvidia 8600gt with 256 megs ddr3 video, (2) maxtor 500gig 7200 rpm drives, an external 1tb dell 7200 drive. The text2d messages are saved on the c: drive in the "my documents folder"
My videos are all mp4 ripped with h264 codec at 7000kbs with 320kbs acc sound at 44.1khz. The only video effect that is running is the text 2d and the clipbank is set to automatically play on audio tracks, but each time it has crashed has been during a video playing (clipbank is loaded with all sheep skin files).
Posted Tue 29 Apr 08 @ 7:21 pm
