this is probably a dumb question but i was wonderin if i can use the dxm01usb with out using my vv box and use my timecodes.
Posted Mon 28 Apr 08 @ 7:05 pm
The VV box is technically not a soundcard but an interface. I do not believe the soundcard in the DXM01USB is an ASIO compatible soundcard.
Posted Mon 28 Apr 08 @ 7:46 pm
You could use that mixer but you would need to use the phono outputs from the VV box into the mixers inputs.
Posted Tue 29 Apr 08 @ 3:37 am
thanks 4 da info guys
Posted Tue 29 Apr 08 @ 12:42 pm
