i always use a laptop fan & an external fan for my harddrive they sell small fans beleive me it will work
Posted Mon 02 Jun 08 @ 2:46 pm
cheers mate for the advice but applying the compound (look at page one) was the cure to my problem, if you don't have any compound between the processors and the heat sinks this will cause your lappy to over heat, of course this is just one cure to many causes... thanks again
Posted Mon 02 Jun 08 @ 3:29 pm
