Yesterday I've bought the DJ Console RMX. I installed the drivers from the CD and Virtual DJ 5.
When I connect the console and start mixing with it, it changes also in Virtual DJ. The only big problem is that there's no sound at all. My OS is Windows Vista Home Premium.
Is it normal that it's only the trial version of VD on the CD?
Does any1 have had the same problem? Can any1 help me?
Thx
Thx
Posted Fri 25 Apr 08 @ 7:59 am
Hi
It is not the trial version it is Home version that has some limitations, take a look here:
http://www.virtualdj.com/products/comparison.html
How did you connect your speakers? Try to setup in Vista>Control Panel>Sound your MK2 as default playback device and connect outputs on MK2 itself.
Posted Sat 26 Apr 08 @ 9:17 am
