Forum: Old versions
Topic: Need help setting up maya 44 USB
Guys
I'm trying to build a system for time coded cd's and I'm having trouble seting up the maya in asio low latecy mode, seems the time code is comming out of the outputs of the maya! When i start vdj it tells me its going to mute the inputs, i select yes and the output is only on 12 channels and sounds like the whine of the time code. When I put it regular mode its fine. Please help this is a 3.0 ghz laptop running 1024 ram. I've read the site instructions to no avail, is it possible i've got a bum maya? not sure.
Posted Thu 23 Dec 04 @ 11:44 pm
bump, plese don't ingnore....
there was a blog from dams explaining the setup... tried to find it, but could not...
maybe he will post it again
bump
anymore advice
the problem is the time code sound is comming out ot the outputs.
