Hi,
This post is for ICDX users.
I was wondering if you use the ICDX to control Virtual DJ, can you use the EFX on the ICDX on a track in Virtual DJ?
Warm Regards,
Pat
Warm Regards,
Pat
Posted Tue 22 Apr 08 @ 9:52 am
You can load and control the parameter of any effect loaded on the chosen deck.
Posted Tue 22 Apr 08 @ 10:24 am
to be exact, you will be using the effects of the computer... not the icdx effects if thats what youre asking
Posted Tue 22 Apr 08 @ 6:54 pm
Hi,
Thanks, That's what I was wondering.
Posted Wed 23 Apr 08 @ 5:42 am
Some aditional infomation.
Posted Wed 23 Apr 08 @ 7:04 am
