I am looking to buy a new laptop to use with Virtual DJ, it will almost certainly be a MacBook or MacBook Pro - however, as a completely new user, I am struggling to understand how to mix when there is only one audio output on almost all laptops...I downloaded the demo of the software on my current laptop, but there seems to be no way to play one track out of the speakers and the second separately out of my headphones in order to mix. Because there's only one output on the laptop, anytime I trying out samples, or match the beats both tracks come out of the speakers...any ideas in terms of using the software or buying new hardware?
Thanks.
Thanks.
Posted Tue 22 Apr 08 @ 7:49 am
see if this helps until you get a second card... http://www.virtualdj.com/blog/tayla/?category=2
Posted Tue 22 Apr 08 @ 7:54 am
