can anyone help me hook up the headphones to a mixer and listen to the song that is on deck without interfiering with the song that is currentley playing
Posted Mon 21 Apr 08 @ 7:01 pm
are u speaking in general like a deck on its own or vdj ? if it's virtual dj have a look at your option configuration something is not right!
I hope that helps. what is your configuration? what do u mix with? put all the details, to get the best help ;)
Angie
Angie
Posted Mon 21 Apr 08 @ 10:08 pm
Posted Tue 22 Apr 08 @ 2:35 am
there is a simailar post at the moment about different versions of Virtual DJ.
but, if youre using the Trial Version, im pretty sure that it is limited to just one output with the main mix from the 2 decks.
so no possibility of headphones.
the hom version is the next step and lets you connect the headphones to the 'rear' output on a 5.1 soundcard.
the full 'pro' version has no restriction on connecting to an external mixer.
Posted Wed 23 Apr 08 @ 7:21 pm
Do I need to have an external mixer, in order to cue songs up. With the full verson of the virtual dj?
Posted Wed 23 Apr 08 @ 10:53 pm
im using the virtual dj 5.0 my question is how can i hook up my laptop to my mixer so that i can listen to the track that is loaded on deck 1 without it interferring with the song that is currently playing on deck 2. can you give me step by step im a beginner
Posted Thu 24 Apr 08 @ 8:02 pm
@gotroc, have you tried utilizing the search feature of the forum? It is a very helpful tool simply because most questions like this have been asked several times. You can save yourself a lot of waiting for answers if you use it properly. Good luck....
Posted Thu 24 Apr 08 @ 8:31 pm
i gave you a link earlier in the thread to get you started, it helps people without external sound cards but if your not gonna bother looking...
Posted Fri 25 Apr 08 @ 3:25 am
