Not for me, still had to use the workaround with selecting 4.1 & other posters had as well, was one of the first things I tested with the 08 drivers. Oh well, I sold my mk2 last week anyway so it's no longer an issue for me;^]
Posted Mon 14 Apr 08 @ 5:54 pm
So will version 8 fix my problem. I really like the mk2 in the home edition. I would like fpr it to work similiar to that. I dont know if the skin that am using makes a difference. Because for example I could not see where i would lower or raise the low mid or high. It was very different. OH and for the smart *** I did not return the money because unlike you I do this for fun and not for a living I charged the guy very very little just enough for gas.
Posted Tue 15 Apr 08 @ 8:43 am
Took me half an hour to work out a decnet config for MK2 and V5.0.7 Works well and the difference in sound is great.
I'll post my settings when I get home
Posted Tue 15 Apr 08 @ 9:08 am
Yes driver 08 do correct the problem that arise with the v5.07, prior to these user use the driver 07. It best u download it too.
The MK2 DJC edition is based on V3, while the Pro Version is based at now V5. Skin n functions are different in the manner as V5 have a lot of improvement added on.
I think what u implying abt is that when u say u can't see the eq section, that because maybe u are selecting the full video default skin. U could go to the config n at the skin tab select the internal mixer default. U need to spend more time with software new feature n i can say that u may like it more than ur djc edition n u may never use the DJC edition again;)
Posted Tue 15 Apr 08 @ 1:46 pm
ok i have been working on this problem
i got the headphones to work when i use 4:1 as my soundcard but i am using the mk2 what am i doing wrong or will it work this way
i dl the new drivers this is what my mk2 says it has
firmware: 1.3.6.13
driver:3.8.0.0
dj api 2.0.14.17
CPl 2.0.1.7
DOES this Look correct?
firmware: 1.3.6.13
driver:3.8.0.0
dj api 2.0.14.17
CPl 2.0.1.7
Posted Fri 18 Apr 08 @ 6:30 pm
