ok I just went to buy the turntable numark tt500 and the Numark v v, they should be here soon take 5 days for delivery.
Ok guys, I'm going need some help setting them up.
these are the things that I have.
Labtop
external hard drive
mixer
amp
equaliser
crossover
mike
two speakers
how do I connect everything in the right oder getting the best sound?
after I get the two turntables and numark vv.
and one last question, when I play my music I get a high pitching sound from my external hard drive; how do I fix that problem?
does a compressor will do the job or there is something else?
thanks
Labtop
external hard drive
mixer
amp
equaliser
crossover
mike
two speakers
thanks
Posted Fri 11 Apr 08 @ 12:42 pm
Howdy it is explained in great detail in the supplied quickstart and reference manual
but briefly , you will connect your TT500s to the VV box on inputs 1 and 2.
You will connect your mixer to output 1 and 2 .
Then you will connect the other devices after the mixer as you would in a traditional setup.
Posted Fri 11 Apr 08 @ 1:46 pm
